Club3D R9 290 Royal Ace Review
The last generation of AMD Radeon cards had a few that stood out about the rest, and one company that really nailed it on with all the different versions was Club3D.
Indeed the cards they provided in the last generation were so good that their HD7970 was the spine of our Ivy Bridge test bench. Given how much abuse our test rigs get we required one that was bulletproof, and in all the time we chopped and changed motherboards, testing CPUs to their limits, and generally mucking about, it never let us down once.
So their cards equipped with the Tahiti core were robust and powerful, so how does their newest addition to the Poker range, the R9 290 Royal Ace, stack up.
Technical Specifications
With the 1040MHz clock speed and plenty of cooling capacity, the Royal Ace (stylised royalAce) should give a good example of whether there is enough in a R9 290 to make the R9 290X worthy of investment, or if a good 290 can still run with the hounds.
Model
Product Name: R9 290 royalAce
Product Series: R9
Item Code: CGAX-R9298SO
EAN Code: 8717249400615
Interface
Bus Interface: PCI Express 3.0
Chipset
GPU Chipset: Hawaii Pro
GPU Clock: ~ 1040 MHz
Stream Processors: 2560
Multi-GPU
Multi-GPU: Dual CrossFire Ready
Memory
Memory Size: 4096MB
Memory Interface: 512BIT
Memory Type: GDDR5
Memory Clock: 5400 MHz
Cooling
Cooling Type: Active Tripple Fan CoolStream
TDP
Idle: 20W
Idle ZCP mode enabled: 3W
Maximum load: 250W
3D API
DirectX version: 11.2 capable graphics
OpenGL version: 4.2
OpenCL version: 1.2
Dimensions
Slot Width: 3 Slots
Profile: Standard ATX profile
Card Size: 308x125x53 mm
Weight
Card Weight: 1410 grams
Output Configuration
DVI: 2x Dual-Link DVI-D
HDMI: 1x version 1.4a
DisplayPort: 1x version 1.2
HDCP ready: YES
RAMDAC: 400MHz
Maximum Resolution Single-Link DVI: 1920×1200
Maximum Resolution Dual-Link DVI: 2560×1600
Maximum Resolution HDMI 1.4a: 4096×3112
Maximum Resolution Mini DP 1.2: 4096×2160
Maximum Outputs Simultaneously: 4
Maximum Display support: 6 (Via DisplayPort and using the MST Hub, please refer to CSV-5300)
In the package
Club 3D AMD R9 290 royalAce graphic card
Club 3D knob hanger
Driver & E-Manual CD
Quick install guide
