DFI Lanparty DK P45-T2RS Plus
Introduction & Specification
DFI are a company that need no introduction on a site such as this. Producing quality motherboards designed for enthusiasts for years, they made their name with what is arguably the best board ever produced - the NF4 SLI-DR. However, I can't help but feel that they have struggled under the weight of their own reputation, with enthusiast expectations being raised to extremely high levels. Still, while the boards that they have produced in recent months may not be able to brand themselves into the memories of enthusiasts as the SLI-DR was, they have been extremely competent and very good performers.
Today we have the opportunity to take a good look over a mid-range orientated board. Designed for people who want good performance without the price tag, this has take form of the DFI Lanparty DK P45-TR2 Plus. The DK (short for dark) has been a relatively new line of DFI boards under the Lanparty header that appeared around the time Intel's P35 chipset was adopted, with the intention being to fill the mid-range gap referred to above. It's occupying a space that I for one have felt DFI have been missing for a while, sitting nicely between the Infinity and Lanparty UT (and more recently the LT) ranges. The range, like its elder UT, can be found in all of Intel's chipset flavours, both DDR2 and DDR3 variants, but bears a fraction of the price tag.
So let's see what the mid-ranged board has to offer us with a look at the specifications taken directly from DFI's own web page:
# LGA 775 socket for: - Intel® Core2 Quad and Intel® Core2 Duo
# Supports Intel Enhanced Memory 64 Technology (EMT64T)
# Supports Enhanced Intel SpeedStep Technology (EIST)
# Supports Intel Hyper-Threading Technology
# Supports 1333/1066/800MHz FSB
# Intel® chipset - Northbridge: Intel® P45 Express chipset Intel® Fast Memory Access technology - Southbridge: Intel® ICH10R
System Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 1066MHz (O.C 1200MHz)
# Delivers up to 12.8Gb/s bandwidth
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered x8 and x16 DIMMs
Expansion Slots
# 2 PCI Express (Gen 2) x16 slots dimensionally with x16 transfer rate lanes for PCIE2 and x8 transfer rate lanes for PCIE4 (16-lane ports, 8-lane ports) - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
# 2 PCI Express x1 slots
# 2 PCI slots
# Award BIOS
# 8Mbit SPI flash BIOS
# CMOS Reloaded
# Realtek ALC885 High Definition audio CODEC
# 8-channel audio output
# DAC SNR/ADC SNR of 106dB/101dB
# Full-rate lossless content protection technology
# Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
# Marvell 88E8053 PCIE Gigabit LAN controller
# Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Serial ATA with RAID
# Intel Matrix Storage technology
# Supports up to 6 SATA devices
# SATA speed up to 3Gb/s
# RAID 0, RAID 1, RAID 0+1 and RAID 5
# JMicron JMB368 PCI Express to PATA host controller
# Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
Rear Panel I/O
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 optical S/PDIF-out port
# 1 coaxial RCA S/PDIF-out port
# 6 USB 2.0/1.1 ports
# 1 RJ45 LAN port
# Center/subwoofer, rear R/L and side R/L jacks
# Line-in, line-out (front R/L) and mic-in jacks
Internal I/O
# 3 connectors for 6 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 front audio connector
# 1 CD-in connector
# 1 IrDA connector
# 6 Serial ATA connectors
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 4 fan connectors
# 1 download flash BIOS connector
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# Ultimate 4-phase digital PWM with 12 MOSFETs
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-LAN
# Wake-On-Ring
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/Northbridge temperature and overheat alarm
# Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
# 4 layers, ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
An impressive specs list with a few features I'm very glad to see on there, like the mass of USB ports (6 on the I/O plate + 6 internal), both optical and coaxial SPDIF out and 8 internal SATA ports (6 on chip, 2 controlled by the J-Micron controller). These are often areas that miss out when it comes to budget boards.
Next we take a look at the board itself and the packaging it came in...
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
19-12-2008, 09:06:34
I don't think i've seen a DFI board look so good since the 939 days...Quote
19-12-2008, 09:33:08
All I get from this tbh is there is absolutely no point in getting it if u have an IP35 Pro. Which in all honesty, including the other 2 mobos, is an absolute disgrace imo.
It also has ALC885 sound.. which is pretty old afaik.
I will say tho, for fear of sounding like a scratched record, I feel these 4 series Intel boards would probably perform better with newer cpus.
Good review, being truthful I`d overlook this unless I see it doing well with newer cpus.Quote
19-12-2008, 09:37:53
bah humbug to you rast ...I see what your saying...if it had been released 18 months ago it may have warranted more attention...still a decent performing board for the money though...I wouldn't build a current system round it but if your in the field for a replacement then its worth a look...although I think DFI may have been better looking at 1377 rather then sticking to an already tried (and tried(and tried)) formula....Quote
19-12-2008, 09:44:05
To be really honest, it`s plain to me that the mobo is less use than the IP35 Pro. I have to wonder how it would cope against the IP35 Pro XE.
So, rather than 18 months, it`d be that time PLUS before the Intel 35 chipset was released.
I seriously don`t see the point in this board. For sure it`s a 35 mobo with a dropped in 45 chipset - purely on availablity I`d imagine.
But does this really signal that the 45 chipset is that much of an insignificance over the 35 ? It does have the advantage of being more ddr3 orientated - so in that sense, why is there not a full bank of ddr3 dimms ? The mere presence of ddr2 dimms means that (from what I read on enthusiast sections) a 45 chipset needs to be crippled to use ddr2. How much I don`t know.Quote
19-12-2008, 10:06:30
hmmmm....I can see why they say crippled....but I suppose its down to the DDR2 in question...(and believe me Ive sold E8400's to people using a 4core dual sata which only takes up to DDR667 and only one channel max 2gb some people) ...
Sorry my mistake I read 45 chip not chipset...thought it was reference to the 45nm wolfdales...duh...but the point about the DDR2 in question still is a valid pointQuote
