DFI Lanparty DK P45-T2RS Plus
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Everest is in many ways similar to Sisoft Sandra. Focusing mainly on software and hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem. Each of these benchmarks were performed a total of 5 times with the highest and lowest scores being discarded and an average calculated from the remaining three.
Observations
The results presented from the CPU and Memory benchmarks show some rather predictable results. The T2RS Plus keeps up with all the other boards tested, although it is slightly overshadowed by the IP35 Pro on the DDR2 front. The only real fluctuation between results that we can see is those boards which utilise DDR2 versus DDR3 memory.
