DFI X58 T3eH8 Ultra Motherboard
Gaming Benchmarks
Crysis is without doubt one of the most visually stunning and hardware-challenging games to date. By using CrysisBench - a tool developed independently of Crysis - we performed a total of 5 timedemo benchmarks using a GPU-intensive pre-recorded demo. To ensure the most accurate results, the highest and lowest benchmark scores were then removed and an average calculated from the remaining three.
Company of Heroes is Relic's first title to make use of the "Essence Engine". This engine was designed and coded from scratch by Relic in order to make use of special graphical effects, including high dynamic range lighting, dynamic lighting & shadows, advanced shader effects and normal mapping. On May 29, 2007 Relic released a DX10 patch for Company of Heroes which was applied for this test.  Running the in game performance test 5 times, the highest and lowest scores were omitted with the average calculated from the remaining 3.
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning "world", "earth" or "living" in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Results Analysis
A 'middle of the road' performance from the DFI T3eH8 in our short round of gaming benchmarks. On this evidence it is clear there is little reason to choose the DFI over any of the other boards unless Tri-SLI is a requirement. Your choices will then be limited to the Gigabyte and the DFI, both of which are amazing overclocking boards.
Maybe PCMark, showing an overview of system capabilities, can put some air between the top two boards...
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
29-01-2009, 09:45:57
It's nice to know some things never change.
Amazing layout? Check.
Bulletproof? Check.
Incomprehensible BIOS options? Must be a DFI
Some great clocks coming out of that. Agree that the current high-end X58s are way too steep. Although the high-end 775 stuff was eye-watering too.
Thanks for the review.Quote
29-01-2009, 09:46:49
Just spotted a typo:
while at first appearance appears very thick is that that daunting once you realise it is a multi language manual.
Probably wanna replace one of the "thats" with "not". Made for an awesome read though- day I can afford kit like this is the day I win the lottery lol.Quote
29-01-2009, 10:03:02
Sounds like he was overcome by the 'Chinglish' manual.Quote
29-01-2009, 10:48:48
its an amazing mobo, it looks pretty good, it has a lot of good points but i still dont know its price, also the asus / msi board results were as good as the DFI mobo, and sometimes even better and i expected more from it afterall DFI is pretty famous, but still its a great mobo Quote
29-01-2009, 14:42:09
Although the results showed the boards to be fairly even (they are afterall all based on the same chipset and run at the same settings), when scoring the boards there are many more points to consider.
The DFI board is not a board to run at stock settings, it isn't designed to do that, anyone who buys this board for that is only after e-peen glory and not using the board for what it was intended for - overclocking. In this area it excels. Therefore DFI have completed what they set out to do. The price they charge reflects the niche market they are aiming for. After all Lamborghinis arn't exactly in the same marketplace or have the same customer in mind as Diatsu.
If you want a board that covers all bases then the Gigabyte board, for me at least, is the better board.
For hassle free 'it just works', reliability then look no further than the Asus P6T.
The MSI, while not a bad board by any stretch of the imagination, offers nothing over the others for the price they are asking.Quote
