DFI X58 T3eH8 Ultra Motherboard
CPU Performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
SuperPI is the benchmark of choice for many overclockers. It's lightweight to download and can give a quick indication on how good a system is at number crunching. Once again, testing was performed a total of 5 times, with an average being calculated from the middle three results.
PassMark is a popular benchmarking suite which test all aspect of PC hardware.The CPU test examines Mathematical operations, compression, encryption, SSE, 3DNow! instructions and more. Each CPU test was performed a total of 5 times, with an average being calculated from the middle three results.
Results Analysis
Nothing extraordinary here with the DFI neither beating nor losing out to the competition. The Passmark CPU mark was a little disappointing but the remainder of the CPU benchmarks show that the DFI is no different from the other boards.
Let's see if there is anything to separate the board with our run of memory benchmarks...
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
29-01-2009, 14:45:57
VonBlade
It's nice to know some things never change.
Amazing layout? Check.
Bulletproof? Check.
Incomprehensible BIOS options? Must be a DFI
Some great clocks coming out of that. Agree that the current high-end X58s are way too steep. Although the high-end 775 stuff was eye-watering too.
Thanks for the review.Quote
29-01-2009, 14:46:49
Kerotan
Just spotted a typo:
while at first appearance appears very thick is that that daunting once you realise it is a multi language manual.
Probably wanna replace one of the "thats" with "not". Made for an awesome read though- day I can afford kit like this is the day I win the lottery lol.Quote
29-01-2009, 15:03:02
JN
Sounds like he was overcome by the 'Chinglish' manual.Quote
29-01-2009, 15:48:48
soapsupah
its an amazing mobo, it looks pretty good, it has a lot of good points but i still dont know its price, also the asus / msi board results were as good as the DFI mobo, and sometimes even better and i expected more from it afterall DFI is pretty famous, but still its a great mobo Quote
29-01-2009, 19:42:09
w3bbo
Although the results showed the boards to be fairly even (they are afterall all based on the same chipset and run at the same settings), when scoring the boards there are many more points to consider.
The DFI board is not a board to run at stock settings, it isn't designed to do that, anyone who buys this board for that is only after e-peen glory and not using the board for what it was intended for - overclocking. In this area it excels. Therefore DFI have completed what they set out to do. The price they charge reflects the niche market they are aiming for. After all Lamborghinis arn't exactly in the same marketplace or have the same customer in mind as Diatsu.
If you want a board that covers all bases then the Gigabyte board, for me at least, is the better board.
For hassle free 'it just works', reliability then look no further than the Asus P6T.
The MSI, while not a bad board by any stretch of the imagination, offers nothing over the others for the price they are asking.Quote
