DFI X58 T3H6 JR mATX Motherboard
Â
HDTach is a free hard disk benchmarking program from SimpliSoftware. This benchmark is not only capable of producing results on hard disk access times but also CPU usage required during disk access. The “Long bench” was run a total of 5 times with the highest and lowest results being omitted and an average calculated from the remaining 3 results.
Â
Â
Â
Â
Â
Â
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Â
Â
Results Analysis
Again, we see there is not a lot to choose between all of the motherboards on test in this test considering all the motherboards are making use of the ICH10R controller. The DFI neither excelled or failed in the run of hard drive benchmarks settiling itself in to the middle of the pack for the majority of tests.
Let’s see how the motherboard performs with our multimedia benchmark suite…
