FOXCONN BlackOps X48 Motherboard
Hard Drive Benchmarks
Published: 17th October 2008 | Source: Foxconn | Price: £255.01 |
HDTach is a free hard disk benchmarking program from SimpliSoftware. This benchmark is not only capable of producing results on hard disk access times but also CPU usage required during disk access. The "Long bench" was run a total of 5 times with the highest and lowest results being omitted and an average calculated from the remaining 3 results.
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Results Observations
Interestingly, both the Foxconn BlackOps and the Rampage Extreme perform slightly better than the Intel P35 Blitz Formula SE chipset, even though all boards make use of the ICH9R controller.
Hi Rast, and thanks for the feedback.
The package as you say is immense, and certainly makes the product as a whole stand out from the rest. I mean who else includes trim-pots ready for voltage modification and and a dry ice attachment for a NB cooling block lol. They (Foxconn) actively encourage users to clock the nuts off the thing.
Pricing is extremely high for both the UK and AUS, but prices are considerably more sedate in the US. So if you really wanted one as part of the ultimate bench rig then you can certainly save some money that way (customs/import duties may apply to UK though).
The fan attachment blows directly onto the cooling channels in the bottom of the block and the warm air escapes the best it can - screw holes or blow-back through the fan itself. The fan doesn't actually cover the whole of the block due to the fan shroud being square and the block being rectangular. Admittedly it's not perfect solution, but it's better than a purely passive approach
Thanks again for the comments and I'm glad you enjoyed the review
Quote
Originally Posted by name='Rastalovich'
Bios looks nice. Like the sound of the dual bios thing - now if u happened to completely screw the one bios via an update or something, can u flush it by booting to the other one ? Or flash it from the other one ? - now that`d be something special.
Great review as always PV.Quote
Key thing - can u manage the one bios from the other ?Quote
One Bios backs up the other so if one Bios becomes corrupt, you can still use the 2nd Bios which will flash the corrupt Bios.
I'm not sure whether you can utilise the 2nd bios with the foxconn board but with gigabyte and asus, the 2nd Bios was there for bios recovery only.Quote
I`m curious about the fan mount on the nb. It blows down into the box... and the air goes where ? Down the pipe ? Out screw holes ?
I dunno tho, if ur hell-bent on the package as a whole and don`t want to pay £146 for a mobo that no1 in the western world has reviewed yet (even tho it`s been out for weeks and every1 is avoiding them like the plague - even out in Australia now
Excellent review PV, tis a great package either way.Quote
