Gigabyte B550 Aorus Master Review
Packaging and Accessories
Published: 16th June 2020 | Source: Gigabyte | Price: £299.99 |
Up Close - Packaging and Contents
The Aorus packaging is now as familiar as any other famous hardware brand, with what we consider to be the screaming eagle large and in charge on the front, allied to the orange lettering that lets you know which model this is. On the reverse all the key features are easily found without resorting to miniscule fonts to cram it all on. Most of us only care about how much we can plug into a motherboard and how fast it will go when we do, and the Aorus Master ticks those boxes in feature terms.
Inside the box we have the clearly written manual and driver CD as well as a healthy collection of cables. First up the SATA ones which are such a feature of every motherboard box on earth that we think the people who makes the cardboard for the box probably include them without being told to.
Monitoring your temperatures is key to keeping a healthy system and the B550 Aorus Master has two thermistor cables letting you keep a close eye on those points where heat might build up in your case.
No RGB LED strip comes with enough cable unless you're running your system in an HTPC chassis, so the inclusion of some extension cables is always welcome. Here they are in plain RGB and Addressable formats.
WiFi without antenna is pointless, so having the Aorus standard design antenna included is very nice too. It's funny how, in a world determined to bring unique and easily recognisable designs everyone has agreed that this is the shape WiFi antennae should be.
Another motherboard release with eye watering prices. B550 is meant to be the knock down cheaper alternative, but they're still pushing out £300 boards!? Mental. B550 lowers the scale of pricing from x570 sure, but am I the only one who thinks we're getting screwed by motherboard manufacturers?
Don't forget that a part of that price is the chipset price also. Like, from AMD. IDK if they charge a license fee like Intel...
Sadly this will just continue, until Intel give them a reason to have to drop.
"We create monsters".Quote
If you use 2 GPUs for rendering well then go for another board, but for most people, this is a much better distribution of lanes.Quote
