Gigabyte B550 Aorus Master Review
PCI Express Layout
Gigabyte B550 Aorus Master Preview
PCI Express Layout
The PCI Express layour is the difference between a lot of the B550 boards. Other than the more visible component specification, VRM quality is going to be how the manufacturers decide to use the PCI Express lanes available between the CPU and the chipset. We have already done a preview on the Aorus Pro Motherboard and the difference between the two boards and how they use the lanes specifically for storage purposes is significant.
The Master's M.2 storage lanes are all PCIe 4.0 which sounds brilliant but it does come with a slight drawback. While the top M.2 is wired directly to the CPU the second and third slots share bandwidth with the PCIe (GPU) connector, so if you use those slots the GPU will run at 8x.
Either way the Master gives you plenty of high speed storage options, but you do just have to consider the impact this may have on the rest of your system.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
17-06-2020, 12:13:42
Avet
I don't know why Tom is so against 3 NVME Gen 4 full speed drives. I think it is a masterstroke. (pun intended) If it was Gen 3 lanes I would understand. Probably not even 3080Ti/3090 will be able to saturate X8 Gen 4. SLI is dead so why not use those PCI-E lanes for uber-fast storage? Two chipset PCI-E slots will be more than enough for any expansion like 10G or capture card.
If you use 2 GPUs for rendering well then go for another board, but for most people, this is a much better distribution of lanes.Quote
19-06-2020, 10:37:50
The_Crapman
Another motherboard release with eye watering prices. B550 is meant to be the knock down cheaper alternative, but they're still pushing out £300 boards!? Mental. B550 lowers the scale of pricing from x570 sure, but am I the only one who thinks we're getting screwed by motherboard manufacturers?Quote
19-06-2020, 13:38:45
AlienALX
Apparently the traces need to be super clean. Meaning the cost goes up. That is at least what I have heard.
Don't forget that a part of that price is the chipset price also. Like, from AMD. IDK if they charge a license fee like Intel...
Sadly this will just continue, until Intel give them a reason to have to drop.
"We create monsters".Quote
