Gigabyte EP45-DS3P (P45) DDR2 Motherboard
Test Setup & Overclocking
Test Setup
Matching our previous reviews of P45 based motherboards, we used the same setup to guarantee a fair review.
 Specs List
During the testing of the setup above, special care was taken to ensure that the BIOS settings used matched whenever possible. A fresh install of Windows Vista was also used before the benchmarking began, with a full defrag of the hard drive once all the drivers and software were installed, preventing any possible performance issues due to leftover drivers from the previous motherboard installations.
To guarantee a broad range of results, the following benchmark utilities were used:
Synthetic CPU & Memory Subsystem
• Sisoft Sandra XII 2008c
• Lavalys Everest 4.0
File Compression & Encoding
• 7-Zip File Compression
• River Past ViMark
Disk I/O Performance
• HDTach 3.0.4.0
3D / Rendering Benchmarks
• Cinebench 10
• 3DMark 05
• 3DMark 06
3D Games
• Oblivion
• F.E.A.R
• Call of Duty 4
Overclocking
Overclocking was on a par with the other P45 chipset based boards we have tested recently. Despite not managing quite as high FSB as the other motherboards reviewed, an overall CPU overclock with our test Q6600 of 3.9 Ghz was impressive. While not the best, it is certainly not the worst and as this is the cheapest board on test it was a very strong showing indeed.
One worrying point though is the amount of Vdrop between the setting in the BIOS (1.55v) and the actual figure in windows (1.504). The Vdroop was also cause for concern drooping 0.078v to 1.472 when testing under 100% load (Prime95). In order to keep the overclocking enthusiasts happy it would have been nice to have included a loadline calibration type setting to prevent this from happening. Still, not a bad showing at all, Let's see how it gets in with our run of benchmarks.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
12-08-2008, 16:15:53
w3bbo
Hmmm - looks like a fine reviewQuote
12-08-2008, 16:25:16
Ham
Slightly raindowish. But pretty nice for the price tbh.Quote
12-08-2008, 20:40:56
FarFarAway
See now that's an enthusiast mmotherboard. Cheap and clocks nice with decent performance. Like it Quote
05-09-2008, 12:34:52
Fake
What BIOS was it flashed too? I have the same motherboard and with an E8500 at 4085MHz but I'm have some troubles. I keep getting BSOD and I looked up the BBCode and they are all memory related. I did some research and apparently the motherboard is picky with the RAM it is used with.
I flashed from the default BIOS to F7 and still getting the same problemsQuote
