Gigabyte H55N USB3
Memory & SATA Performance
Memory & Hard Disk Drive Performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC.
Circa 11GB/sec on such LGA1156 systems are very much what you would expect in SiSoft Sandra's Memory test. Both systems are predictably on par with each other here.
Interestingly the HDD Test outputted identical results for both motherboards. While this is to be expected when both use the same H55 chipset, it indicates a very low error margin within the test itself.
Everest Ultimate Edition's memory testing suite determines the performance of your memory and your system's memory controller. Both Read and Write operations are tested.
Do bear in mind that these results cannot be compared with SiSoft Sandra's test. Regardless, these results are very much the expected results for the aformentioned platform.
Hard Disk Performance
HDTune
HDTune analyses the performance and health of your Hard Disk Drive. It's comprehensive test will determine minimum, maximum and average transfer rates.
The H55 chipset has little trouble at making the most of our Samsung Spinpoint F1 Hard Disk Drive.
«Prev 1 2 3 4 5 6 7 8 Next»
16-06-2010, 10:59:35
Diablo
great review, but the maximum futuremark vantage scores are all identical and lower than the averages. Otherwise excellent work, and looks like a new ITX champQuote
16-06-2010, 11:23:22
Rastalovich
One of the futuremark graphs looks weird, with the average being bigger than the max. (or it could be my coffee's gone cold)
What's the ALC892R like ? Very important to me that.
Other than that, £90 (mrrp?), upto £10 off for online stores, I would definitely look for this one in something like a Scan Today special. If it went for £75-£80 it sounds a bargain.
Great stuff.Quote
16-06-2010, 12:52:30
Mul.
Hi guys
It would seem that I forgot to apply the correct labels on the Vantage graph. Minimum Maximum and Average actually refererred to Overall Score, GPU Score and CPU Score respectively.
As for the ALC892R, honestly I could not fault it. The sound quality was crisp enough and appeared to be at least as good as the previous 889 series.Quote
21-06-2010, 08:59:51
leuis9
Atlast Gigabyte have a better motherboard device.having a maximum storage capacity with good intel processor.For Clarkdale processors, overclocking and underclocking is made easy thanks to a fully working multiplier control, and the ability to under-volt or over-volt CPUs in the H55N-USB3 BIOS. Memory overclocking is also rather good, all memory sub-timings are available, and each timing has an AUTO parameter which will scale with frequency, requiring no user-intervention to reach high operating speeds. Quote
