Gigabyte X570i ITX Aorus Pro WiFi Review
Passmark
Published: 27th October 2019 | Source: Gigabyte | Price: |
Passmark
Like PC Mark, Passmark tests the abilities of your whole system from raw calculation tasks through 2D and 3D graphics performance all the way up to storage speeds. It's an excellent test of the overall capabilities of your system.
I'm so tempted to build a mITX setup which would use NH-D15 as a cooler but be otherwise as compact as possible with only m.2 storage, etc. But I can't justify it as with my usage (mainly gaming) swapping out 8700k for either Ryzen 3 or upcoming LGA2066 wouldn't be anything but a sidegrade. And just swapping motherboards sounds a tad silly.
This one looks pretty good considering the footprint that chipset cooler and the AM4 bracket has.
Glad to see that ports are being moved to the correct side of the ram slots. Done a few ITX builds where there have been fan headers or SATA ports on the other side of the ram slots and it just makes the whole thing look messy.Quote
