Gigabyte X570i ITX Aorus Pro WiFi Review
CPU Temperatures
Gigabyte X570 I Aorus Pro WiFi Review
CPU and VRM Temperatures
The biggest thing we were concerned about with the Gigabyte X570 Aorus ITX Pro was the limited cooling options but clearly the Gigabyte designers have left enough room to allow us to push Ryzen 9 3900X much further than we anticipated whilst not breaking into temperatures that we are uncomfortable with. Even the VRMs, the one area you might expect this extreme processor to cause problems for this tiny board, only hit 79°C which we find astounding. Running a more sane processor will naturally lower all of this temperatures.
VRM temperatures are very good for such a small board running such a ludicrous processor. It's worth bearing in mind that, unlike their competitors, the Gigabyte VRM temperature sensor is on the VRMs themselves rather than just nearby, thus it will always be a little higher as it's reading the pure temp.
Gigabyte X570 I Aorus Pro WiFi Temperatures
VRM Temperatures
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Next»
28-10-2019, 08:01:58
looz
I'm so tempted to build a mITX setup which would use NH-D15 as a cooler but be otherwise as compact as possible with only m.2 storage, etc. But I can't justify it as with my usage (mainly gaming) swapping out 8700k for either Ryzen 3 or upcoming LGA2066 wouldn't be anything but a sidegrade. And just swapping motherboards sounds a tad silly. Quote
28-10-2019, 10:19:28
Dawelio
This sounds basically like my setup, having an 3700X, only one 2TB M.2 drive, mITX board that will go inside either the Dan Case A4 SFX or the NCASE M1 Quote
28-10-2019, 12:48:04
demonking
I do love a good ITX build.
This one looks pretty good considering the footprint that chipset cooler and the AM4 bracket has.
Glad to see that ports are being moved to the correct side of the ram slots. Done a few ITX builds where there have been fan headers or SATA ports on the other side of the ram slots and it just makes the whole thing look messy.Quote
