Gigabyte X570i ITX Aorus Pro WiFi Review
Test Setup and Overclocking
Gigabyte X570 I Aorus Pro WiFi Review
Test Setup
We know that we're asking a lot of the Aorus Pro ITX board by fitting it with the Ryzen 9 3900X, but not only might this spring some performance surprises but it also has the twofold benefit of letting us compare it to the other X570 motherboards we've reviewed whilst also look at the compact design in its worst case scenario. We can't imagine anyone looking at this will plump for the 12 core beast, but it's fun to discover if the Gigabyte motherboard can handle it.
Gigabyte X570 I Aorus Pro WiFi (F6b)
AMD Ryzen 9 3900X
G.Skill Trident Z 3600 MHz
Corsair Vengeance RGB 4600 MHz
Corsair MP500 M.2 - OS Drive
Aorus PCIE4 NVME - Storage Speed Tests
Nvidia RTX 2080Ti
Corsair HX1000i
Corsair H150i
Corsair ML Fans
Overclocking
If there was any thought that the sole 8 pin CPU 12V input might limit the performance possibilities of the Gigabyte ITX Aorus Pro then they are quickly dispelled with a very impressive overclock. 4.34 GHz across all twelve cores from such a compact motherboard is not to be sniffed at, and actually it ends up in the middle of the X570 pack.
Gigabyte X570 I Aorus Pro WiFi Overclocking
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Next»
28-10-2019, 08:01:58
looz
I'm so tempted to build a mITX setup which would use NH-D15 as a cooler but be otherwise as compact as possible with only m.2 storage, etc. But I can't justify it as with my usage (mainly gaming) swapping out 8700k for either Ryzen 3 or upcoming LGA2066 wouldn't be anything but a sidegrade. And just swapping motherboards sounds a tad silly. Quote
28-10-2019, 10:19:28
Dawelio
This sounds basically like my setup, having an 3700X, only one 2TB M.2 drive, mITX board that will go inside either the Dan Case A4 SFX or the NCASE M1 Quote
28-10-2019, 12:48:04
demonking
I do love a good ITX build.
This one looks pretty good considering the footprint that chipset cooler and the AM4 bracket has.
Glad to see that ports are being moved to the correct side of the ram slots. Done a few ITX builds where there have been fan headers or SATA ports on the other side of the ram slots and it just makes the whole thing look messy.Quote
