Gigabyte X570i ITX Aorus Pro WiFi Review
AIDA64
Gigabyte X570 I Aorus Pro WiFi Review
AIDA64
Since its early days as Everest, AIDA64 has provided an excellent way to benchmark your system without requiring you to take a week off work whilst the tests run. From the memory bandwidth benchmarks which test your throughput, to the CPU benchmarks which vary in scope to test everything from raw calculation – CPU Queen – through compression algorithms – zLib – and the all important encryption – AES256.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Next»
28-10-2019, 08:01:58
looz
I'm so tempted to build a mITX setup which would use NH-D15 as a cooler but be otherwise as compact as possible with only m.2 storage, etc. But I can't justify it as with my usage (mainly gaming) swapping out 8700k for either Ryzen 3 or upcoming LGA2066 wouldn't be anything but a sidegrade. And just swapping motherboards sounds a tad silly. Quote
28-10-2019, 10:19:28
Dawelio
This sounds basically like my setup, having an 3700X, only one 2TB M.2 drive, mITX board that will go inside either the Dan Case A4 SFX or the NCASE M1 Quote
28-10-2019, 12:48:04
demonking
I do love a good ITX build.
This one looks pretty good considering the footprint that chipset cooler and the AM4 bracket has.
Glad to see that ports are being moved to the correct side of the ram slots. Done a few ITX builds where there have been fan headers or SATA ports on the other side of the ram slots and it just makes the whole thing look messy.Quote
