Gigabyte X58A UD3R V2 Review
UD3R Up Close
Published: 8th November 2010 | Source: Gigabyte | Price: £149 |
Up Close
The UD3R v2 certainly doesn't push any boats out when it comes to design, following on perfectly from its v1 counterpart and the rest of the Gigabyte range. An information packed box gives way to the standard blue board with sky-blue and white slots that we're all familiar with.
Here you can see the many PCIe slots with the rather curiously placed legacy PCI slot as I mentioned in the video. You can also see on the bottom right the red-marked "Charge" USB header. This allows a much greater power-draw than USB standards so you can charge your iPhone/Mobile much quicker than normal.
The CPU area is where the main changes are found with the increased amount of power circuitry to better deliver smooth power and greater overclocking performance. The Gigabyte heatsinks always look lovely with clear writing and a nice deeper blue than that of the slots.
The RAM area is kept fairly clear. Normally this is where companies cram those few things they couldn't find room for elsewhere but Gigabytes design keeps everything in sensible places and allows this to have maximum airflow to keep the DIMMs and CPU cool.
Despite still retaining FDD and IDE compatibility the focus is definitely on SATA slots with 6 SATA 2 and 4 SATA 6G/bps sockets covering your storage requirements.
The front panel connectors, so often a bane of our lives, are once again well served by Gigabytes continued use of a very clear, colour-coordinated, header.
The IO panel contains everything you'd expect to see from PS2 ports, SPDIF, USB 3.0 to Audio, Firewire and LAN.
Fantastic stuff. I need not worry as if I ever go X58 then this is the board I shall get. The original is an absolute legend and this one seems to make the design even better. And the price is sensational too. This is the board that CPC gave a massively high score to saying that it made all of the models above it (in the Gigabyte range) redundant due to them being no better for functionality and that they came with loads of bolt on tat that didn't do anything. |
I look forward to it though and thanks for the review
Fair enough. But price to performance they are cutting their own throats. Let's say for example the 7 costs £300. Will it offer double the performance of the 3? I look forward to it though and thanks for the review ![]() |
Ps just joined the site but been reading reviews last couple weeks and really like what you guys are doing compared to most sites and for my new rig certainly couple decissions will be based on your reviews. THANKSQuote
This is the board that CPC gave a massively high score to saying that it made all of the models above it (in the Gigabyte range) redundant due to them being no better for functionality and that they came with loads of bolt on tat that didn't do anything.Quote
