Gigabyte X670E Aorus Master Review
CPU Temperatures
Our CPU temperature testing is a juxtaposition between best and worst case scenarios. We run a seriously heavyweight CPU cooler, which shows the best use case, and then torture the system for 30 minutes to get our peak reading. Otherwise known as the worst case scenario. Â Note that our overclock is always fine-tuning the volts in a way that a stock setup doesn’t, and thus usually ends up running cooler than stock.
