Gigabyte Z170X Gaming 7 Review
BIOS
The Gigabyte BIOS is one of the easiest to use that we’ve experienced. Everything is clearly labelled and usually clearly explained. The only things that aren’t obvious are the ones that you don’t need to be fiddling with anyway. It might have taken us a long while to get the system up and running, but once it was it was incredibly easy to get a stable overclock. The Gaming 7 had no difficulty in reaching the limits of our test i7-6700K.
