Gigabyte Z370 Aorus Gaming 7 Review
Passmark
Published: 5th October 2017 | Source: Gigabyte | Price: £274.99 |
Passmark
That curious state of affairs continues into Passmark. If you look at the raw numbers and compare them to their brethren there isn't anything obviously bad, hell there isn't even anything that would be cause for concern, yet the sum doesn't quite equal the parts.
Have had trouble with the Aorus software and ended up removing the lot except for the Aorus Graphic Engine. I need that to create a fan profile for my Aorus 1080ti . Sad thing is you cant get the card and the mobo to be friends using that software.Quote
5Ghx @1.26V
X Hero:
5Ghz @1.31V
...not using the same CPU?
...or what is going on there?
Gaming 7:
5Ghx @1.26V X Hero: 5Ghz @1.31V ...not using the same CPU? ...or what is going on there? ![]() |
Not my own results.Quote
