Gigabyte Z68X UD5 B3 Review
Sandra and CineBench
Sandra Processor Arithmetic
Once again with our i5-2500K at stock the Z68X UD5 just doesn't seem to be up there with the best of the P67 boards yet. Overclocked is something else though and it's very much on a par with the highest performers.
CineBench R11.5
The always reliable CineBench rendering test merely echoes our findings. This is a board at its best when overclocked and merely average at stock.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
12-05-2011, 15:12:12
adamjamesroe
Looks ok, but a bit expensive, nice review though. Quote
12-05-2011, 15:51:08
dugdiamond
nice mobo - but for the price i would rather have a sabertoothQuote
12-05-2011, 15:54:58
SieB
Not as impressive as I thought it was going to be but as said it's not a bad motherboard. Z68, apart from the addition of SSD caching doesn't really seem worth it tbh, I know some of the boards offer the use of the IGP but if you are spending over £150+ on a motherboard it seems a waste to use the IGP and not a proper GPU.
With the IGP you also get the Lucid chip (on some boards) and the ability to overclock the CPU where as on H67 you only get use of the IGP which can be overclocked but no CPU overclocking and P67 no use of the IGP and only CPU overclocking.
Combining the use of the IGP and being able to overclock both IGP and CPU is good, but again if you are spending money on a decent motherboard i'd say it's best to go with P67 with a proper GPU or a high end Z68 motherboard with a proper GPU. The SSD caching is good but i would like to see the tech mature a bit to see what it is fully capable of on future motherboards.
Good review anyway Bryan Quote
18-05-2011, 06:16:09
Luger718
the igp can also be used for encoding
ive seen mediashow espresso 6 benchmarks that show it encoding twice as fast then a gtx 560 tiQuote
18-05-2011, 09:34:04
SieB
I read about that in this months Custom PC, not about the 560s but the igp. You can only use it on boards with the Lucid chip though but still it's a good feature to have. You can also switch between using you GPU to using the IGP or you can use it to boost the performance of the GPU, on the Asus boards with the Lucid chip anyway.
Also in Intels key notes at CES they showed the Quick Sync encoding being faster than a 580 .Quote
