i5 11600K vs AMD Ryzen 5 5600X with RTX3080 Gaming Review
3DMARK: Time Spy
Published: 12th April 2021 | Source: OC3D | Price: AMD £299.99 Intel £229.99 |
3DMARK: Time Spy
Time Spy is an excellent demonstration of GPU limits. Once you reach a certain level of CPU score, 4000 points plus, there isn't much extra performance to be gained and it's down to the GPU to do the rest. Which is exactly why you should spend your budget for a gaming rig on a better graphics card instead of a better CPU.
I didn't know Intel i5 performed that well, and much cheaper than Ryzen 5. Other than replacing a Ryzen 2000 and keeping your motherboard, I would say Intel is the way to go for a new build.Quote
Why no Cyberpunk 2077 benchmark?
I didn't know Intel i5 performed that well, and much cheaper than Ryzen 5. Other than replacing a Ryzen 2000 and keeping your motherboard, I would say Intel is the way to go for a new build. |
In my analysis pieces on Cyberpunk, I used a different area for CPU and GPU tests. Our typical test area for the game is not that CPU-heavy, making it useless for CPU-focused performance testing.
Finding a new benchmark area for this one article would have added a lot of work to an already time-intensive testing scenario.
The new i5 does offer a lot of value for gamers. TBH I'm not sure if I'd go AMD or Intel this gen if I was making a gaming system. Both are great options and both are on what appear to be dead-end CPU sockets. DDR5 is coming, and that means that both camps will be using new CPU sockets soon.Quote
Many people say this regarding DDR5 etc, but many don't keep in mind that we don't know when they might actually drop. And when they do, they will most likely cost a lot - just for the memory alone.
