Intel 11th Gen Core i5-11600K and Core i9-11900K Review
AIDA64
Published: 30th March 2021 | Source: Intel | Price: |
AIDA64
Since its early days as Everest, AIDA64 has provided an excellent way to benchmark your system without requiring you to take a week off work whilst the tests run. From the memory bandwidth benchmarks which test your throughput, to the CPU benchmarks which vary in scope to test everything from raw calculation – CPU Queen – through compression algorithms – zLib – and the all important encryption – AES256.
Well, 11600K looks fairly solid for gaming, if power efficiency isn't important. Looks to be as far as the architecture scales reasonably, more cores is pretty awkward thermals wise.
In fact 11600K is probably the go to CPU for gaming builds now, until AMD undercut it with a 5600 non-X. But I don't think they have the fabrication capacity. |
The i5 having stock is their only possible power move when AMD stock is quite hard to come by at the momentQuote
But seeing how Intel has their own fabs, not entirely unexpected.
Thanks for the reviews! That's a massive amount of benchmarks.Quote
In fact 11600K is probably the go to CPU for gaming builds now, until AMD undercut it with a 5600 non-X. But I don't think they have the fabrication capacity.Quote
