Intel Core i5-12400F DDR4 vs DDR5 Review
AIDA64
AIDA64
Since its early days as Everest, AIDA64 has provided an excellent way to benchmark your system without requiring you to take a week off work whilst the tests run. From the memory bandwidth benchmarks which test your throughput, to the CPU benchmarks which vary in scope to test everything from raw calculation – CPU Queen – through compression algorithms – zLib – and the all important encryption – AES256.
Whilst the memory latency naturally favours the DDR4 setup, and DDR5 has the raw throughput, the two setups are basically identical in CPU terms here.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
05-01-2022, 12:48:18
Dicehunter
This in an SFX build with small form factor GPU like 3060/3070 would make a killer portable LAN party rig..... if we were allowed LAN's in the current climate Quote
10-01-2022, 12:37:09
Peace
The question I'm asking myself now is whether or not the 100 extra bucks for a 12600KF are worthwile even more to get the E-cores.Quote
10-01-2022, 12:47:56
Warchild
That depends also on it the etailer/store sticks to $100. I see them adding their own markup on them in addittion, so if that happens i would say its not worth it.Quote
