Intel Core i9 9980XE 18 Core CPU Review
3D Mark
Published: 2nd December 2018 | Source: Intel | Price: |
3D Mark
Fortunately for whatever odd results PC Mark gives us, 3D Mark is solid as a rock. You can also see that almost any CPU will be enough to power your system so that you're GPU limited, and the i9-9980XE is no exception.
Those are insane temperatures. I mean, it's amazing that we've hit a temperature ceiling with something like a 360mm AIO at max fan speeds. It shows how Intel's CPUs scale with voltage and remain stable. But it feels like such a shame, like such an odd product.
Intel has lost the plot!Quote
How is 68 degrees insane?
If you complain that is gets hot when you start OC'ing then you are missing the point here. This is not a product made for manual OC'ing.
It seems to run perfectly fine, when used as intended.Quote
