Intel i5 760 Review
Introduction and Technical Specs
Published: 19th August 2010 | Source: Intel | Price: |
Intel's LGA1156 socket and subsequent P55 chipset were designed to be the low cost alternative to the LGA1366 X58 Core i7 platform. Although upon first release it sold in such enormous quantities that prices remained high it didn't take too long before it was possible to build a 1156 based system for a sensible amount of money.
It's actually become one of the best value platforms available, akin to the AM3 socket on the AMD side. It supports everything from the dual-core Pentium based G6950, via Hyper-Threaded Dual Core i5 6 series, the Quad Core i5 7 series all the way up to the Hyper-Threaded Quad Core i7 8 series.
There certainly is a processor for every pocket and application. Today we're looking at the latest model in the i5 range, the top-of-the-line i5 760.
Technical Specifications
If there is one thing that Intel can't be accused of it is making too great a leap forwards in their processors. While many sites such as Overclock3D and overclockers everywhere have shown that nearly every model in the range will happily run all day at 4GHz, Intel are insistent upon these tiny incremental clock speed increases. It has been the way since the original Pentiums and so it's unlikely to change now.
So from Intel themselves, here are the specifications for the Core i5 760.
Status | Launched |
Launch Date | Q3'10 |
Processor Number | i5-760 |
# of Cores | 4 |
# of Threads | 4 |
Clock Speed | 2.8 GHz |
Max Turbo Frequency | 3.33 GHz |
Intel® Smart Cache | 8 MB |
Bus/Core Ratio | 21 |
DMI | 2.5 GT/s |
Instruction Set | 64-bit |
Instruction Set Extensions | SSE4.2 |
Embedded Options Available | No |
Supplemental SKU | No |
Lithography | 45 nm |
Max TDP | 95 W |
VID Voltage Range | .6500V-1.400V |
Intel® Turbo Boost Technology | Yes |
Intel® Hyper-Threading Technology | No |
Intel® Virtualization Technology (VT-x) | Yes |
Intel® Virtualization Technology for Directed I/O (VT-d) | No |
Intel® Trusted Execution Technology | No |
AES New Instructions | No |
Intel® 64 | Yes |
Idle States | Yes |
Enhanced Intel SpeedStep® Technology | Yes |
Intel® Demand Based Switching | No |
Thermal Monitoring Technologies | No |
Execute Disable Bit | Yes |
As you can see the Core i5 760 is identical to the previous Core i5 750, barring a tiny increase in clock speed from 2.66GHz to 2.8GHz. At least this small increase doesn't come at a increase in price as most sites have them identically priced or in some cases the 750 is slightly more expensive.
Do you want me to lend you a piece cloth and some cleaning liquid so that you can clean that horrible stain off your monitor |
I only chucked my new 760 in my also new P55-UD5 last night and redone my loop.
Never ever overclocked on the P55 / X58 platforms before but it took about 3 mins to work out how to up to 4GHz at 1.23v with memory at 2000Mhz.
Tried to quickly chuck it up to 2133MHz with an overclock on the CPU of 4.26 GHz but at that voltage it only just booted into Windows.
When I've rebuilt my OS, I'll get some proper overlocking done on it.
Oh yeah, temps while Prime95'n overnight hit a max of 59 degrees.Quote
You aint wrong about it needing bugger all voltage and running cool. I only chucked my new 760 in my also new P55-UD5 last night and redone my loop. Never ever overclocked on the P55 / X58 platforms before but it took about 3 mins to work out how to up to 4GHz at 1.23v with memory at 2000Mhz. Tried to quickly chuck it up to 2133MHz with an overclock on the CPU of 4.26 GHz but at that voltage it only just booted into Windows. When I've rebuilt my OS, I'll get some proper overlocking done on it. Oh yeah, temps while Prime95'n overnight hit a max of 59 degrees. |
