MSI B350 Tomahawk AM4 Motherboard Review
AIDA64
MSI B350 Tomahawk Review
AIDA64
In keeping with the 'motherboard for the masses' theme, the Tomahawk puts out some very good numbers in our AIDA64 tests, with none of the results having to hide their heads in shame, and the memory scores putting some better boards in its shadow.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
28-03-2017, 00:52:04
NeverBackDown
Not finished reading through the review (haven't watched the video yet either) but I am pretty impressed with those OC numbers from a lower end board. Basically the same as all the other expensive boards.
Edit: really strange results for the Gaming benches. The CH6 is at least an extra 15FPS ahead of all the other boards(in the OC test)? How in the world does a motherboard make that much of a difference?Quote
28-03-2017, 09:46:11
tinytomlogan
So far the only difference would be BCLK overclockQuote
28-03-2017, 15:30:57
Daiyus
Yeah, the fact that a low end motherboard achieved such a solid overclock with the top-tier eight-core makes me much more hopeful that decent speed on an mITX board with a six-core R5 will be possible.
Now we just need to see if ASUS will do an X300 version of their Z270i.Quote
29-03-2017, 09:14:17
CEUOTC
Running this board with Bios Version 1.31. Can get my Corsair LPX 3200 @ 2933 with X-AMP. Can l ask which Bios Version was running for this review TTL?Quote
29-03-2017, 09:32:18
tinytomlogan
I cant remember the number now, it was one MSI sent over and I cant check because the board has gone back already.
Try upping your SOC volts and manually setting 3200MHzQuote
