MSI B350 Tomahawk AM4 Motherboard Review
SiSoft Sandra
Published: 27th March 2017 | Source: MSI | Price: |
SiSoft Sandra
The good performance we saw in AIDA64 continues into Sandra, with the Tomahawk making good use of its overclock to cause some very heavy hitting motherboards to sweat a little.
Not finished reading through the review (haven't watched the video yet either) but I am pretty impressed with those OC numbers from a lower end board. Basically the same as all the other expensive boards.
Edit: really strange results for the Gaming benches. The CH6 is at least an extra 15FPS ahead of all the other boards(in the OC test)? How in the world does a motherboard make that much of a difference? |
Now we just need to see if ASUS will do an X300 version of their Z270i.Quote
Running this board with Bios Version 1.31. Can get my Corsair LPX 3200 @ 2933 with X-AMP. Can l ask which Bios Version was running for this review TTL?
Try upping your SOC volts and manually setting 3200MHzQuote
Edit: really strange results for the Gaming benches. The CH6 is at least an extra 15FPS ahead of all the other boards(in the OC test)? How in the world does a motherboard make that much of a difference?Quote
