MSI B350 Tomahawk AM4 Motherboard Review
Sandra Cryptography and Analysis
MSI B350 Tomahawk Review
Sandra cont
It drops down the graphs a little in the second of our two batches of SiSoft Sandra tests, but when you look at the actual numbers there still isn't much between them, particularly for a entirely different chipset.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
28-03-2017, 00:52:04
NeverBackDown
Not finished reading through the review (haven't watched the video yet either) but I am pretty impressed with those OC numbers from a lower end board. Basically the same as all the other expensive boards.
Edit: really strange results for the Gaming benches. The CH6 is at least an extra 15FPS ahead of all the other boards(in the OC test)? How in the world does a motherboard make that much of a difference?Quote
28-03-2017, 09:46:11
tinytomlogan
So far the only difference would be BCLK overclockQuote
28-03-2017, 15:30:57
Daiyus
Yeah, the fact that a low end motherboard achieved such a solid overclock with the top-tier eight-core makes me much more hopeful that decent speed on an mITX board with a six-core R5 will be possible.
Now we just need to see if ASUS will do an X300 version of their Z270i.Quote
29-03-2017, 09:14:17
CEUOTC
Running this board with Bios Version 1.31. Can get my Corsair LPX 3200 @ 2933 with X-AMP. Can l ask which Bios Version was running for this review TTL?Quote
29-03-2017, 09:32:18
tinytomlogan
I cant remember the number now, it was one MSI sent over and I cant check because the board has gone back already.
Try upping your SOC volts and manually setting 3200MHzQuote
