MSI Big Bang Marshal P67 Review
SiSoft Sandra
Published: 28th March 2011 | Source: MSI | Price: |
SiSoft Sandra
Processor Arithmetic
Sandra is very good at separating the processor away from the rest of the system and focussing in on how good the synergy between the processor and the motherboard are. In the case of the MSI Marshal it's clearly well refined with great performance at stock and trading punches with the Maximus IV when it's pushed to 5 GHz.
Processor Multi-Media
Once again the results at stock are very impressive and with the easy overclock it is like a freight train. Relentless number crunching abilities.
Anyway that's an amazing board, one thing with the technical specs, it says it can't run 3 way SLI, so if you want to fill up all the slots you're pretty much stuck with AMD?Quote
Excellent review as always. Anyway that's an amazing board, one thing with the technical specs, it says it can't run 3 way SLI, so if you want to fill up all the slots you're pretty much stuck with AMD? |
