MSI H55M ED55
CPU Performance
Published: 17th February 2010 | Source: www.msi.com | Price: £89.00 |
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC.
PhotoWorxx as the name may suggest tests processors by means of invoking functions that are common to Photo Manipulation including Fill, Flip, Crop, Rotate, Difference and Colour to B&W conversion.
CPU Queen is based on branch prediction and the misprediction penalties that are involved.
This is an integer based benchmark that will test the CPU and Memory by means of the CPU ZLib compression library.
WinRAR
WinRAR's embedded Benchmark focuses on the processor's File Compression capability.
The H55M ED55 based testbed gets off to a very respectable start. For most of the part, the MSI holds near identical scores with the Asus P7H57D EVO, although in Everest Ultimate Edition's CPU Photoworxx test, an interesting performance advantage is noted at 2.93GHz.
