MSI P55-GD80 Motherboard
Memory Benchmarks
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Everest is in many ways similar to Sisoft Sandra. Focusing mainly on software and hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem. Each of these benchmarks were performed a total of 5 times with the highest and lowest scores being discarded and an average calculated from the remaining three.
Results Analysis
Because of the limitation of using the OC Genie mentioned previously, the memory bandwidth was limited to 1260MHz until MSI sort this issue out (which they have promised to do immediately so hopefully it will be resolved by the time you read this). So to save MSI's blushes I set the GSkill memory of our test bench to it's rated 2000MHz due to overclocking the base clock as opposed to the maximum 1600MHz allowed from the stock memory dividers. This is the same on most P55 boards so it is something worthy of consideration should you wish to purchase high frequency memory modules. The good news is that the 2000MHz setting worked without a hitch.
Let's see how the boards perform in our Hard Drive benchmarks...
21-09-2009, 02:35:28
I'll say it before, and I'll say it again. This is one of the best looking boards I've seen!
That's a nice clock from it too.Quote
21-09-2009, 05:37:05
It's a good mobo with a good review.
£178 is something for the 'con' section for me tbh.
For some reason, since i7, it appears the standard is to have the level of mobos at around £30-50 more expensive than they probably should be.
This could however be the result of 775 mobos just not going away. And if they're at "reasonable" prices, it tends to suggest the manufacturers feel they can "get away with charging" that much more as it's "new technology".
I personally think this is bllx however when the jump between the 2 isn't great.Quote
21-09-2009, 07:26:20
I think Rastalovich has a good point. For £180 you can pick up a mid range X58 board that might not have as many bells and whistles as the P55-GD80 but does have the advantage of 32 PCI-E connectors. Granted for it to make a difference you would need to be running Crosfire/SLI with a 24 inch monitor but the sort of people who this board targets it is quite reasonable to expect they may be running this sort of hardware.Quote
21-09-2009, 12:09:22
I agreee to a certain extent about the price and mentioned in the review that the board should be priced around £20-30 cheaper. However, this is new technology, albeit slightly inferior in certain sectors to older X58 chipsets and because of that the price is inflated accordingly. I couldn't really put the price as a 'con' as it is pretty much inline with what other manufacturers are charging for a flagship P55 motherboard.
The jump between the two technologies is indeed nothing to shout from the rooftops about but the performance difference is there. How much you value that extra performance will depend alot on how much of an investment you see a PC as.
As always guys I appreciate constructive criticism and feedback, these are afterall - reviews for YOU!Quote
21-09-2009, 12:25:19
Only really the same thing I always moan about W3bbo. Solitary performance figures are nice, but a comparison with a same speed X58 i7 system would be lovely.
Would triple-channel make that much difference with it's superior bandwidth?
Given the tiny price difference between this mobo and a 860 and a P6T and a 920D0 which is the better buy?
All those kind of things. Especially important when it's a new generation of hardware and so most people would be buying the bulk of a new system.
Even, because it's equal in dual-channelness to the AMD Phenom IIs, a AMD comparison.
I'm just a comparison whore. I love to know what the best system would be for the same money. Most online comparisons are strange things like a stock i5 vs a i7 975E vs a X2 250. Let's equal the clocks, equal the RAM and run the battery of tests. That way it's clear which is the best for general use, gaming use, productivity etc.
But, as per usual, a fantastic review. Truly droolworthy looking mobo. About the only mobo that comes close in looks is the Asus Maximus III.Quote
