MSI P67A-GD65 Motherboard Review
Crysis Warhead & AvP
Published: 31st January 2011 | Source: MSI | Price: £142.99 @ Aria |
Crysis Warhead
Well it's still perfectly playable. Although the MSI doesn't reach the heights of the rest of our benchmarks it still keeps Crysis ticking away about 60 FPS. It's a bit of a double-edged sword as it remains playable, but is still 6 or 7 frames behind what we'd expect. That could just be Crysis Warhead being its usual strange self though.
Alien vs Predator
Thankfully we can end on a positive note as the heavily GPU dependant Alien vs Predator benchmark gives us very level results throughout all our tests. Even if the GD65 at stock trails, it's only a tenth of a frame, so nothing that isn't within error tolerance.
So perhaps the truly brilliant OC Genie will be the solution to the poor stock performance?
If it works as good as it does on my P55-GD65 then weeeeeeeeeeeeeeeeee
I finally thought MSI was going good in the mobo section yet this is pretty disappointing to me
EDIT i must be fair i also hear people using it and its perfectly fine,
i guess my luck comes in again....Quote
EDIT: Quite a few people seem to get 4.2GHz clock, so I guess MSI is being extremely conservative, in case someone got a half completed chip or something.Quote
