MSI X470 Gaming M7 AC Preview
Up Close continued
Up Close cont
Ensuring that your CPU is fed with a sufficient amount of smooth power is vital, particularly when you're dealing with multi-core processors, and to this end the MSI Gaming M7 has two 8pin CPU power inputs.
Getting a close look at the top right and you can see what we meant about the slightly curious fan header placements. Sure you can make the argument that a single fan CPU cooler is still the most popular option, but at this end of the market when you're dealing with enthusiasts the vast majority of people at minimum use a single fan AIO and most use dual fans necessitating three headers in close proximity.
Like the other X470s we've looked at so far, the Gaming M7 has six SATA 6Gb/s ports to go along with its two M.2 ports. As M.2 prices continue to fall the importance of having multiple slots will only enhance in the future. All that speed for a relatively modest investment.
The MSI overclocking once won our OC3D Innovation award and time hasn't diminished its capabilities. We would always recommend learning how to manually overclock because the results are significantly better but if you're just after squeezing a bit more performance out in a 'fire and forget' manner then the MSI system is outstanding.
Continuing the theme of curiously placed connectors, the front panel USB 3.1 connector is a reasonable way in along the bottom edge. Those with short cables need not apply. Given how most case manufacturers treat cable as something that is worth more than gold and refuse to give you a millimetre or two more thanis the bare minimum then we think that will be a lot of people.
There is just a single fan header on the left hand edge above the PCI Express x1 slot. Hopefully one exhaust fan is all you require.
Another look at the RGB Dragon logo and reinforced PCI Express slots.
Around the back we find a reasonable selection of USB ports, including the all important USB 3.1 in both Type-A and Type-C variants, whilst the 5 GHz WiFi support is built into the X470 chipset along with a Gigabit LAN for those who prefer their internet hard wired. There is also a combined PS/2 port and the all important audio outputs.
«Prev 1 2 3 4 Next»
13-04-2018, 16:11:42
Darkdayzzz
On page 4, the last photo of the lighting...is that...is that lighting on the back of the board?
Like does it shine through to the front of the mobo or strictly on the back of the board? I know I'll know the answer next week when reviews can go live but I'm impatient when it comes to noticing odd things Quote
14-04-2018, 07:04:43
AlienALX
Decent looking board, nice spec. Really don't like the dragon, at all. Cue vinyl wrap in 3-2-1.....Quote
14-04-2018, 23:07:31
Excalabur50
I have the X370 version of this board and it's really good and the dragon looks pretty good IRL. The main disappointment though is the RGB is more procarbon rather than the X370 but i do like how the wifi is built in rather than an ad on card like mine.
The biggest issue that I have with MSI is their RGB implementation is GARBAGE they need much better software control than they have ATM./Quote
