MSI X58 Platinum Motherboard
Test Setup, Power Consumption & Overclocking
Test Setup
To ensure that all reviews on Overclock3D are fair, consistent and unbiased, a standard set of hardware and software is used whenever possible during the comparative testing of two or more products. The configuration used in this review can be seen below:
During the testing of the setup above, special care was taken to ensure that the BIOS settings used matched whenever possible. A fresh install of Windows Vista was also used before the benchmarking began, with a full defrag of the hard drive once all the drivers and software were installed, preventing any possible performance issues due to leftover drivers from the previous motherboard installations. For the 3DMark and gaming tests a single card configuration was used.
To guarantee a broad range of results, the following benchmark utilities were used:
Synthetic CPU Test
• Sisoft Sandra 2009
• PassMark CPU test
• SuperPI 1m, 8m, 32m
Memory Test
• Everest 4.60
File Compression & Encoding
• 7-Zip File Compression
• River Past ViMark
Disk I/O Performance
• HDTach 3.0.4.0
3D / Rendering Benchmarks
• Cinebench 10
• 3DMark 05
• 3DMark 06
• 3DMark Vantage
3D Games
• Crysis
• Far Cry 2
• Company of Heroes
Overall System Performance
• PCMark Vantage
Power Consumption
Power consumption was measured at the socket using a plug-in mains power and energy monitor. Idle readings were taken after 5 minutes in Windows. Load readings were taken during a run of 3DMark Vantage.
At idle, it is clear that the Asus board uses less power than the MSI Platinum X58 but things even out once the boards are put under stress. No software or BIOS power saving features were used during the testing which may or may not improve things further should you choose to install them. We took the readings under a clean environment with only the bare minimum of drivers and Vista updates installed.
Overclocking
Using a respectable Vcore of 1.45v, the remainder of BIOS voltage settings were left in their stock state to ensure equality throughout the testing.
Overclock
Sadly, the maximum overclock I could attain with the MSI Platinum was lower than expected with a maximum Bclk value of 193 which also gave us our maximum overclock of 3850. Anything over this amount resulted in a BSOD on boot sequence which was strange, as the settings above were stable within Windows. No amount of tweaking the dividers and multipliers would improve the situation and so after a couple of hours fiddling with the settings I finally admitted defeat and moved on.
Let's take a look at how the MSI Platinum performs in our benchmarking section..
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
22-12-2008, 19:03:06
monkey7
Very good review, was a good read
1.44V for 3.85gHz Now I'm even more proud of my UD5 doing [email protected] Did you adjust the VTT voltage too? It's just as important as vCore.Quote
22-12-2008, 20:28:53
Rastalovich
Great review. Think they're still crazy priced tho.
Hopefully they see some sense l8r in the 09.
Don't have much exerience with MSI mobos, but I am surprized there's no SLI.Quote
22-12-2008, 22:28:48
Bungral
Quality review as always Rich. Bit miffed at lack of SLI seeing as it's such a massive selling point. Puts it at an instant disadvantage. Ah well.Quote
23-12-2008, 10:56:36
fruityness
Couple of features I picked up on which I thought were great; the first being the right angled sata plugs.. Such a simple thing! But would make tidy cabling easy - it's just impossible to make the sata cableslook neat if they are sicking up out of the mobo.The other was the bios save feature, thats pretty cool! And a great feature, being able to swop from "warp speed overclock" to "mr easy going day to day" at the press of a button.. 10/10 for that one.
£240 though? Too much I think.. Needs to come with the kitchen sink at that price, and it doesnt.
A fine review.Quote
23-12-2008, 12:46:32
w3bbo
I got 4.2ghz on the UD5 I'm currently testing. The MSI was a different beast all together .
Yeah, me too. The boards have to go to Nvidia for 'approval' after which SLI can be endorsed. I believe Nvidia are charging a fortune for this endorsement.
Yup, I agree totally m8. It wouldn't be so much of an issue if the board were priced much lower to compensate but at present it is not.
A fine review.
Thanks for the feedback and I agree on all points.Quote
