NZXT N7 and N5 Z690 Review
Test Setup and Clock Speeds
Test Setup
NZXT N7 Z690
NZXT N5 Z690
DDR4 - Corsair Dominator Platinum 3600 MHz
Intel Core i9-12900K
Windows 11 64bit
Sabrent 4TB Rocket Plus
Nvidia RTX 2080Ti
Corsair AX1600i
Corsair H150i with Noctua 3000 RPM fans
Clock Speeds
The two motherboards are so similar, as is the case with all the Z690 chipset options, that we'll just be showing off the N7 today. We've tested the N5 enough to see that the pair were basically identical, so rather than fill our graphs with two motherboards producing the same results we'll combine them under a single result.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
