Resizable BAR Tested with Intel - The Power of Boosted Memory Access
Assassin's Creed Valhalla
Published: 30th January 2021 | Source: OC3D Internal Testing | Price: |
Like our original AMD testing for Smart Access Memory/Resizable BAR, enabling Resizable BAR on an Intel-powered system has a transformative effect on Assassin's Creed Valhalla. 1st percentile, average and maximum framerates are all boosted, so much so that our Resizable BAR results at 1440p are very close to our standard (Resizable BAR disabled) 1080p results.
It is clear from this result that Resizable BAR support can benefit Intel-powered systems, which is great for systems like our i9-10850K test system.
https://i.imgur.com/xC8nCuW.pngQuote
Bring on the RTX Bios's with this feature enabled, not sure why Nvidia is taking so long, it seems the driver is already prepped.....
https://i.imgur.com/xC8nCuW.png |
Nvidia needs to do a lot of validation before it goes public. They need to make sure that enabling this does not add new bugs or degrade performance in some instances.Quote
Yeah I heard that AMD disables Resizable BAR on driver level for many titles, since it can lead to issues.
Let's just hope that motherboard manufacturers don't lock this for the cheaper models...Quote
