XFX 780i SLI Motherboard
3D Game Results
quake 4
Quake 4 is a game built on the Doom 3 engine. Benchmarking was performed using Quake4Bench and a custom timedemo recording along with 0xAA, 0xAF settings at a resolution of 1024x768.
Quake 4
The XFX 780i SLI gets lower-middle ground in the Quake 4 test.
F.E.A.R.
F.E.A.R. is a game based on the Lithtech Jupiter EX engine. It has volumetric lighting, soft shadows, parallax mapping and particle effects. Included in the game is a benchmark facility that taxes the entire PC system. This benchmark was run 3 times to ensure uniformity of results.
F.E.A.R.
Again F.E.A.R. shows the XFX 780i SLI board near the bottom of the pile performance wise.
Bioshock logo
Bioshock is a recent FPS shooter by 2K games. Based on the UT3 engine it has a large amount of advanced DirectX techniques including excellent water rendering and superb lighting and smoke techniques. All results were recorded using F.R.A.P.S with several identical runs through the same area of the game.
Bioshock
Again a low score from the XFX 780i board surprises as single card gaming performance seems not to be the 780i's strong-point.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
31-01-2008, 16:25:23
Brooksie
XFX always do have lovely bundles..
Looks like the 780i isn't what was expected with the overclocking..Quote
31-01-2008, 16:26:10
FarFarAway
Well 3600ish is OK, remember it is chip and cooling dependentQuote
31-01-2008, 16:59:51
brad81
Hi guys!
First visit to the website to read your review was pretty informative!
I know that the P35 chipsets work well with the new (not so new now I guess) Intel Quads and the ATI/AMD Radeon cards. You stated earlier that for the sake of uniformity that you'd use the Radeon card. I personally believe that because of this the board wasn't shown in fairness to the other boards. Being an Nvidia chipset, would it have not been wiser to use a similar performing card to the Radeon?
Cheers,
BradQuote
31-01-2008, 17:07:36
FarFarAway
A graphics card should not perform any differently in theory under different chipsets. We don't use an Intel card
A "similar performing" card wouldn't perform the same and numbers wouldn't be comparable I'm afraid. Plus using an Nvidia card could also be construed as bias too so we use the same card for all boards.
I do understand your point but we try to make sure every review item is looked at as fairly as possible so we have to decide on one card to use, and this time around we went for an ATI X1950 Pro
EDIT: And welcome Quote
31-01-2008, 18:05:40
Rastalovich
A great read tbh. It is very true that XFX spend time on their packaging for all their products. (I have an XFX badged raid card, as well as the obvious, and it`s evident there too)
I know Kemp has something up his sleeve regarding a sli testing, I can sense it in the air
The sli has to be a big deciding factor in leaning towards these 780i boards (not to state the obvious).
So will it`s `good` to `nearly as good as` performances in other departments stand it in good stead.
Since I`m not a convinced SLI supporter, it`d be easy for me to not suggest these 780i boards to people - however, if their SLI performance is as good as proposed, u`d have to take them seriously and not just for the benchmark chasers.
Dissapointed with the audio outputs, would like to have seen eSata ports, but can understand why they were omitted.Quote
