XFX 780i SLI Motherboard
Synthetic CPU & Memory Results
sisoft
Sisoft Sandra is a synthetic benchmark utility capable of reporting and benchmarking a wide range of system components. For the motherboards we run both the CPU and Memory benchmarks three times to ensure accuracy of results.
sisoft cpu arith
cpu arith int whetstone
sisoft cpu multi int
sisoft cpu multi float
sisoft memory bandwidth int
sisoft memory bandwidth float
The 780i gets average results across the board for the SiSoft CPU and memory tests.
 everest
Everest is in many ways similar to Sisoft Sandra. Focusing mainly on Software and Hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem.
everest memory read
everest memory write
everest memory latency
Again in Everest the XFX 780i SLI gets fairly middling results, certainly nothing to write home about.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
31-01-2008, 16:25:23
Brooksie
XFX always do have lovely bundles..
Looks like the 780i isn't what was expected with the overclocking..Quote
31-01-2008, 16:26:10
FarFarAway
Well 3600ish is OK, remember it is chip and cooling dependentQuote
31-01-2008, 16:59:51
brad81
Hi guys!
First visit to the website to read your review was pretty informative!
I know that the P35 chipsets work well with the new (not so new now I guess) Intel Quads and the ATI/AMD Radeon cards. You stated earlier that for the sake of uniformity that you'd use the Radeon card. I personally believe that because of this the board wasn't shown in fairness to the other boards. Being an Nvidia chipset, would it have not been wiser to use a similar performing card to the Radeon?
Cheers,
BradQuote
31-01-2008, 17:07:36
FarFarAway
A graphics card should not perform any differently in theory under different chipsets. We don't use an Intel card
A "similar performing" card wouldn't perform the same and numbers wouldn't be comparable I'm afraid. Plus using an Nvidia card could also be construed as bias too so we use the same card for all boards.
I do understand your point but we try to make sure every review item is looked at as fairly as possible so we have to decide on one card to use, and this time around we went for an ATI X1950 Pro
EDIT: And welcome Quote
31-01-2008, 18:05:40
Rastalovich
A great read tbh. It is very true that XFX spend time on their packaging for all their products. (I have an XFX badged raid card, as well as the obvious, and it`s evident there too)
I know Kemp has something up his sleeve regarding a sli testing, I can sense it in the air
The sli has to be a big deciding factor in leaning towards these 780i boards (not to state the obvious).
So will it`s `good` to `nearly as good as` performances in other departments stand it in good stead.
Since I`m not a convinced SLI supporter, it`d be easy for me to not suggest these 780i boards to people - however, if their SLI performance is as good as proposed, u`d have to take them seriously and not just for the benchmark chasers.
Dissapointed with the audio outputs, would like to have seen eSata ports, but can understand why they were omitted.Quote
