AMD HD6790 Review
AMD HD6790 Overclock 3D Mark Review
Up Close
Our model of the HD6790 is an OEM version, so devoid of any stickers or fanciness. In this guise you can really see how uninteresting the reference cooler is. No vents or areas that will assist cooling in Crossfire.
AMD HD6790 Board Review     AMD HD6790 Circuit Board Review
The business end of the HD6790 follows the standard AMD pattern which enables Eyefinity. Dual DVI, HDMI and twin DisplayPort cover your output needs.
Power is provided by two PCIe 6-pin which should make sure the HD6790 gets all the power it could require even in overclocked trim.
AMD HD6790 Outputs Review     AMD HD6790 Power Review
Finally the only remotely noticeable feature is the standard red fan. We’ve been quite damning in our criticism of the noise that this generates normally, so we’re interested to discover if it’s much quieter now it wont have as much heat to shift.
AMD HD6790 Cooler Review     AMD HD6790 Reference Review
