AMD Radeon RX 6900 XT Review
Total Warhammer 2
Published: 15th December 2020 | Source: AMD | Price: |
Total Warhammer 2
Creative Assembly rewrote the book for strategy games with their Total War series, and with Total Warhammer they brought fantasy into that sphere. Total Warhammer 2 took all that was great about the first entry and filled it so full of content that you can play the Mortal Empires campaign for literal years if you wish. The CPU does as much work as the GPU here, thanks to hundreds of units and vast draw distances.
Other people have said in their review that they think something is wrong on the driver and/or firmware side, A card with a fair chunk more under the hood should perform better, Not match a lower tier card or just slightly edge it out in certain titles, Unless RDNA2 really doesn't scale well like AMD said in the past and there are diminishing returns beyond a certain CU count.Quote
Great review Tom !
Other people have said in their review that they think something is wrong on the driver and/or firmware side, A card with a fair chunk more under the hood should perform better, Not match a lower tier card or just slightly edge it out in certain titles, Unless RDNA2 really doesn't scale well like AMD said in the past and there are diminishing returns beyond a certain CU count. |
There's diminishing returns for overclocks as well. Hitting 2.8Ghz is nice, but it only introduces a little extra performance.
Overclocking works well providing you keep the thing cool, failing that it is a case of diminishing returns because of throttling.Quote
When the Asus Strix 6900 XT LC turns up it will be a beast because of the AIO unit it comes with.
Overclocking works well providing you keep the thing cool, failing that it is a case of diminishing returns because of throttling. |
Lets just hope the pump on it doent make a horrible whining noise like all the EVGA AIO cards..Quote
They look like pro cards, no bells, whistles or blinky LEDs. Its been a while since I really liked an AMD reference card design.Quote
