AMD Radeon RX 6900 XT Review
Control
Published: 15th December 2020 | Source: AMD | Price: |
Control
Remedy Entertainment’s Control is one of those games that demonstrates everything available to you in modern engines and with modern hardware. Not only does it have destructible environments but it supports all the hardware tricks, including Ray Tracing and DLSS on hardware with either or both of those features. We’re testing in every possible combination to demonstrate how each can impact your frames per second. The first graph is all resolutions in 'plain' mode. The second graph with Ray Tracing on, something which isn't the strong suit of the first generation of AMD RT cards.
Other people have said in their review that they think something is wrong on the driver and/or firmware side, A card with a fair chunk more under the hood should perform better, Not match a lower tier card or just slightly edge it out in certain titles, Unless RDNA2 really doesn't scale well like AMD said in the past and there are diminishing returns beyond a certain CU count.Quote
Great review Tom !
Other people have said in their review that they think something is wrong on the driver and/or firmware side, A card with a fair chunk more under the hood should perform better, Not match a lower tier card or just slightly edge it out in certain titles, Unless RDNA2 really doesn't scale well like AMD said in the past and there are diminishing returns beyond a certain CU count. |
There's diminishing returns for overclocks as well. Hitting 2.8Ghz is nice, but it only introduces a little extra performance.
Overclocking works well providing you keep the thing cool, failing that it is a case of diminishing returns because of throttling.Quote
When the Asus Strix 6900 XT LC turns up it will be a beast because of the AIO unit it comes with.
Overclocking works well providing you keep the thing cool, failing that it is a case of diminishing returns because of throttling. |
Lets just hope the pump on it doent make a horrible whining noise like all the EVGA AIO cards..Quote
They look like pro cards, no bells, whistles or blinky LEDs. Its been a while since I really liked an AMD reference card design.Quote
