Ashes of the Singularity PC Performance Review
4K Testing with AMD R9 Fury X and Nvidia GTX 980Ti
Moving to our 4K testing we see that AMD's R9 Fury X and Nvidia's GTX 980Ti continue to perform similarly at Low settings, with both GPUs actually performing worse with the DirectX 12 API. This changes when we move up the graphical settings, but it does show that DirectX 12 does not necessarily mean better performance in games.
Moving to higher graphical settings we see that AMD gains the performance advantage, with AMD R9 Fury X being able to achieve average framerates of around 40 at even 4K Crazy settings.
At standard settings and higher AMD's R9 Fury X has a clear performance advantage over the GTX 980Ti at 4K, offering higher minimum and average framerates when using both the DirectX 11 and DirectX 12 APIs.
Nvidia's GTX 980Ti has decreased performance when using the DirectX 12 API at all settings in Ashes of the Singularity, whereas in pretty much all situations apart from the games lowest settings AMD has a performance increase. This performance increase for AMD seems to be down to Asynchronous Compute, which is a performance enhancing DirectX 12 feature that is unique to AMD GPUs right now.
When looking at Ashes of the Singularity at 4K High settings it is pretty hard to think that the GTX 980Ti is similarly priced to the R9 Fury X, with the AMD GPU offering an 11FPS performance advantage to Nvidia when using DirectX 11, with an even larger performance gap at DirectX 12.
In most games at 4K the AMD R9 Fury X and the GTX 980Ti are almost always neck and neck, but in Ashes of the Singularity AMD's R9 Fury X is the easy victor. Oxide games have always stated that they are brand neutral and that they have not programmed the game to give either side an advantage, but we must remember that this developer was a former AMD Mantle developer and that this game has DirectX 12 features that are AMD exclusive at this time.
At 4K high settings we see that both AMD's R9 Fury X and Nvidia's GTX 980Ti drop below 30FPS minimum framerates, though the Fury X does stay above that level of performance most of the time.
Given how forgiving strategy games can be when it comes to average framerate (outside of the competitive scene), the game is pretty playable on AMD's R9 Fury X at 4K extreme settings, whereas on Nvidia's GTX 980Ti is is often below 30FPS when looking at battles, taking a lot away from the gameplay experience.
At 4K crazy setting the game moves to become nigh unplayable on Nvidia's GTX 980Ti but remains mostly playable on AMD's R9 Fury X. In large battles both GPUs move to become jittery slideshows, but outside of battle the game is still pretty easy to control.
Ashes of the singularity is best played with a high framerate, especially if you want to sit back and enjoy watching your units do battle without the game becoming a slideshow.
04-04-2016, 16:34:06
Relayer
Do you have 390(X), 970, 980 cards on hand to test? It would be good to see how these perform since so many gamers own them. In some games lately Hawaii has been getting pretty close to Fury(X) performance.
Thanks,Quote
04-04-2016, 16:44:49
WYP
Thanks,
Sadly I do not have an R9 390 or GTX 970 for performance testing.
All of the GPUs that I use for testing have been bought and paid for by me the writer and were not samples from an external party or sponsor. Hopefully we can get hold of more GPUs for gaming content in the future, especially when the next generation of GPUs are released.Quote
04-04-2016, 21:33:03
NeverBackDown
Right now only AMD GCN GPUs support Asynchronous Compute in their GPU drivers, though Nvidia is rumored to be adding support for this function to Maxwell in the future with a driver update, though this remains unconfirmed by Nvidia.
AMD supports it on a hardware level as well as driver level. Nvidia won't be releasing a driver for it, driver can't make up for hardware losses, it's not possible for Nvidia to implement such a feature.
I find it kind of funny that now AMD in DX11 are either slightly behind or just ahead. Nvidia really are struggling with this title, explains why they called Oxide out before. Hopefully as they push out more content it gets more optimized and less CPU limited in future updates/patches.Quote
05-04-2016, 08:32:58
SPS
I'd be more interested to see different CPUs used, from both Intel and AMD's offerings. Though I do appreciate that you don't have access to everything or necessarily the time either.
Oxide most likely focused on GCN optimization which kind of explains why Nvidia benefit on DX11. Not sure how you know Nvidia can't support async compute, they don't really share architecture notes.Quote
05-04-2016, 11:18:59
NeverBackDown
Even in dx11, they aren't much better as everything gets higher resolution or settings. I doubt it's mostly AMD focused, it uses asynchronous compute. Nvidia doesn't have it and therefore probably results to context switching to do both compute and graphic work so it adds latency and therefore decrease framerate. AMD called out Nvidia at GDC that you can't support it at a driver level. In addition, it's been what 6 months and we've had no comment or hints from Nvidia about this "rumored" magic driver. I think it's more likely that got started by people saying, "wait for them to release a driver for the game". I don't even think Nvidia has a proper driver for it yet.. or not for a while. Which makes sense since they called out Oxide saying its not represenitive of a real dx12 title and begging them not to use asynchronous compute. That's just them being sore losers tbh. Nothing wrong with admitting that they can't support it but will try to get the best performance possible anyway. They haven't done this for any other dx12 title, it's just because they lose by far in this oneQuote
