Asus 5850 TOP Review
Intro and Tech Specs
When a new product gets launched we always see a bunch of reference designs that change in nothing but the sticker for a while. Gradually as the product matures we start to see factory overclocked models and eventually ones with non-reference coolers.
The ASUS Top range has always been one that combines both elements of a factory overclock and a non-reference cooler to potentially provide one of the best performing models of that type around.
Of course the model that you start with has a large bearing on the quality and performance of the finished product, so we were delighted that the latest in the Top range is based upon the Radeon HD5850, a card we've already tested in stock format and found to have plenty of overhead available if you're willing to tweak.
Technical Specifications
As always we popped along to the ASUS website to grab the technical specifications and see what we've got to play with.
Graphics EngineATI Radeon HD 5850
Video MemoryGDDR5 1G
Engine Clock765 MHz
Memory Clock4500 MHz ( 1125 MHz DDR5 )
Memory Interface256-bit
CRT Max Resolution2048 x 1536
DVI Max Resolution2560 x 1600
VGA OutputYes x 1 (via DVI to D-Sub adaptor x 1 )
DVI OutputYes x 2 (via HDMI to DVI adaptor x 1 )
HDMI OutputYes x 1
HDCP SupportYes
Adaptor/Cable bundled1 x DVI to D-Sub adaptor
1 x Power cable
1 x HDMI to DVI adaptor
Software BundledASUS Utilities & Driver
The two main features of note besides the factory overclock are the ASUS Voltage Tweak BIOS which enables us to "give it the beans", and the DirectCU which is ASUS Direct Contact Cooler which should keep the noise and temperatures down.
«Prev 1 2 3 4 5 6 7 Next»
09-04-2010, 06:27:08
grammer error on the dirt 2 introQuote
09-04-2010, 08:41:27
Spelling mistake..... AMDQuote
09-04-2010, 08:58:25
There's an error on the Dirt2 graph labels. I think 'Top Stock' and 'OC Ref' are the wrong way around - according to the description you gave.Quote
09-04-2010, 10:09:29
alryt my badQuote
09-04-2010, 12:38:54
Glad you boys pay attention. Helps us feel good about our work.
Graph key on Dirt2 graph was backwards. Fixed. So words are right, graph is right, key was wrong.
