Asus EN 8800 GTX - nVidia's G80 Performance Revealed
Game Tests - Quake 4 and Oblivion
Quake 4
Quake 4 is a game built on the Doom 3 engine. This uses many DX 9.0c features and is a game that has not always ran so well on ATI hardware, being an OpenGL game. Once again I did three two minute runs on Quake 4 on each card and took the average of all my readings from these. I played a fast and furious part of the game that required both internal and external scenes.
Here are the settings that were found to be optimal for Quake 4 on a Dell 2405FPW:
quake 4 settings
oblivion fps graph
Quake 4 also ran ultra-smooth at these ultra-high details setings. Settings like this in Quake look very nice with not a jaggy in sight. Once again the 8800GTX nailed Quake 4 and was kept back by the rest of the system.
Oblivion is an awesome RPG with a simply huge immersive environment, great graphics and incredibly realistic scenery. This game is currently one of the most testing games that you can buy and it is certainly a test of the high-end cards here. I chose to do a run-through of the Arena part of the game. I spoke to a character, did some magic whilst in a fight and fought in the arena that is pretty huge. Also as well as doing this test I took a wander around to make sure that the benchmark resembled the general gameplay with each card. This benchmark really tests today's cards and ATI cards seem to do very well in this game, with nVidia cards lagging behind slightly.
Also note that I used the "Chuck" patch to enable AA and HDR for the ATI cards this was integrated in ATI's latest drivers. The nVidia card also allowed me to run the game with AA and HDR.
Here are the settings that were found to be optimal for Oblivion on a Dell 2405FPW display:
oblivion settings
oblivion fps
As I mentioned earlier: Oblivion is probably the most challenging game out on the market. Previously I could just about run it smoothly on the X1950XTX on 2 x AA. With the 8800GTX this is all taken in the cards stride and I felt that the restriction was once again on the test system's CPU. Oblivion is an awesome game and with 8 x QAA added onto the scene as well as HDR it is an immersive and almost spell-binding universe.
It's great to see nVidia manage to get HDR and AA in most situations with the 8800GTX and the sheer speed that the card implements this is beyond what we were imagining could be done before 8800 came out.
«Prev 1 2 3 4 5 6 7 8 9 Next»
24-12-2007, 17:24:49
Great insight into the higher end of the gpu spectrum.
I have to be fair, even tho u`ve got a 1 to 4 positioning, I don`t think there`s that much in it for any of them. I know the Ati slides in the rankings, but it does show itself to be a fine card.
An interesting comparison would have been performance versus costing, seeing as they`re as close as they appear to be.
I`m a bit at odds with the oc results too. I simply can`t achieve the memory overclock on my GT without it having fits. But I can clock the gpu to around 720 (from 670).
What would impress me is some1 buying the cheapest GT, putting it under water, and claiming back those clock hertz with their superior cooling. Sounds nice.
Suprizes me a bit tho that the GTS isn`t launched as a bigger performer. Although pricewize, it does seem to start from stock where the GT limit starts. Leaving u further to climb
Nice review m8, think every1s doing the "going to bed early to get up early" trick Quote
24-12-2007, 17:25:40
Nice to see this review is finally up
Shame I cant view it as 128k is painfully slow :sleep:Quote
24-12-2007, 18:07:43
Thing is though there is a BIOS voltmod for the 8800GT that GREATLY increases its overclockability. If there isn't one for the 8800GTS I see them both reaching high limits but so far the 8800GT seems to OC better. With good cooling and the volt mod this thing easily passes 800mhz core, I've seen some at 850+.
What you also go to look at as well is shaders, they seem to be the key thing atm if the shaders OC much better on the 8800GT, which I guess they kinda should since they could simply lock the worst performing ones to get it top out better, it could impact performance in certain titles a lot.
Nice review though I was surprised the 8800GT didn't clock more, there wasn't a heat issue was there?
It should also be said about the supposed problems of the memory modules on the 8800GT, seems that long term use of the memory at 2ghz+ and it brakes. Thats why some companies like Zotac use better memory modules for their cards.Quote
24-12-2007, 18:29:40
Great review Kempez, can't wait to open my GTS tomorrow Quote
24-12-2007, 18:34:22
The GT was a little hot yes, but I will never change the cooling or take off the heatsink prior to running any tests. I test every card as it would be when it appears on your doorstep
Volt-modding is not part of the overclocking testing as the percentage of users who do that is small and it voids any warranty you have.
An overclock is dependent on what RAM is used, what cooling is like and also what luck you get with the silicon...the overclocking gods didn't smile on me this time
@Rast: I agree, the ATI card is a great card as I said in the ATI review, but this review was for these two cards. Having said that: would I buy the HD3850 personally? No, I'd go for an 8800 GTS 512mb G92 or an 8800 GT 512 G92 It's simply not fast enough with every game, I'm afraid.Quote
