ASUS GTX960 Strix Review
3D Mark Vantage
Published: 22nd January 2015 | Source: ASUS | Price: £189 |
3D Mark Vantage
Our first benchmark and the GTX960 is extremely close to the GTX760, and a shade behind the R9 280. We don't want to start making assumptions based on a single result, so let's see how 3D Mark 11 fares.
"In nearly every title the GTX960 comfortably outperforms the GTX750Ti, GTX760 and, more often than not, the GTX770."
It does indeed outperform the 750Ti in everything, much to be expected. But sometimes the 760 outperforms the 960 sometimes. I don't know about you, but I find this fact simply appalling. Performance (sometimes) went down after an entire generation? I don't see the 770 outperforming (or even getting close to) the 970, or the 780 to 980 the same. Why is the 960 seemingly gimped compared to those, and how/why is this acceptable or even good?
You also state the 960 more often than not outperforms the 770. There are only like 5 charts in the entire review it ties or beats the 770, out of 16, and not by much at all. How exactly does the 960 more often then not perform better than the 770 if this is the case?
I think the only impressive thing about this card (and the 960 as a whole from all the reviews I have seen so far) really is it's power usage. Which is pretty impressive indeed. I think because the 960 is a blend of the 750Ti (same memory controller etc) and a cut down 970.
If/When AMD counter with a price cut, I don't really see much reason for anyone to buy a 960 honestly.
Also. I don't know if you have noticed, but the PCB of the ASUS 960 actually has a 192 bit bus (6 memory locations with only 4 filled), its simply not used on the 960. Almost guaranteed that there will be a 960Ti soon which is what the 960 should have been originally.Quote
This is pretty amazingQuote
