ASUS nVidia GTX590 Review
Test Setup and Overclocking
ASUS GTX590 Review
Test Setup
nVidia GTX590
Intel Core i7-950 @ 4GHz
ASUS Rampage III Extreme
Muskin Joule 1200w
6GB Mushkin Redline
Noctua NH-D14
Windows 7 Ultimate x64
One quick reformat and we're running the identical setup that we just tested the HD6990 on. It couldn't be a more accurate battle of the two challengers for the throne.
Overclocking and Temperatures
Obviously with a twin GPU there are many extra considerations on top of the normal ones we have to think about when overclocking. We are not only playing the silicon lottery, but we also are limited by the lower maximum clock of the two. Furthermore there are limits to the amount of power that you can draw from the PCI-e socket and heat that the heatsink/fan combo are capable of expelling.
Even with these limitations the GTX590 managed to be pushed from its default 613MHz to 660MHz which should be enough to give us some boosts in testing.
ASUS GTX590 Review
Temperatures
Showing that nVidia and Asus are being conservative, under load the overclock only gives us a 2°C maximum increase over the stock card. A decent non-reference cooler and this could go into the 700s.
 ASUS GTX590 Review     ASUS GTX590 Review
«Prev 1 2 3 4 5 6 7 8 Next»
24-03-2011, 13:00:42
sources95
sweet mother of jesus!Quote
24-03-2011, 13:05:30
MR J DAWG
that thing is BEAST!!!!Quote
24-03-2011, 13:05:49
Zeals
Wow they really turned down the GPUs in this thing.Quote
24-03-2011, 13:06:54
sources95
Just imagine that thing with a waterblock...Quote
24-03-2011, 13:09:52
tinytomlogan
Ill post the [email protected] stats here in a bit but basically 6800 WU's were 13k on each core. All the details are in the video though. (had to go careful with uploading too early on this one but the vid will be up asap)Quote
