ASUS ROG Strix XG32V Curved 32" Freesync Monitor Review
ASUS ROG Strix XG32V Curved Gaming Monitor Review
When it comes to displays, our requirements are pretty simple. You want one that has good gaming performance so that you're not suffering from ghosting and tearing. We'd like accurate colour reproduction so that everything you look at and work with - particularly photo editing given how we've all got high megapixel cameras on us at all times - looks exactly as it should. Lastly we want a stand that is adjustable enough to have the screen at a perfect ergonomic position to enable us to work and game comfortably for long stretches. If it also has some cool additional features then yay, but naturally the display portion takes precedence.
But no matter what the bare facts of the situation might be, no matter how unemotional we have to be, we have to start with the looks and the more subjective experience of sitting in front of this thing.
The XG32V absolutely dominates your view. 32 inches of curved loveliness. It fills your vision in a manner that, until now, you had to invest in multiple screens to enjoy. We're used to 24 and 27 inch monitors here at OC3D, neither of which are exactly small, but 32 inches is a ridiculous amount of real estate to sit 18 inches away from. If the scale wasn't enough to excite then the curvature only exacerbates the experience as your whole world goes from being something that exists outside the bezel of your display, to something which is your whole world. If you're a movie going person then it's like moving from a multiplex to a IMAX theatre. It's almost obscenely spectacular.
Okay. That's the emotional, subjective, part of the experience out of the way. What about the more tangible things?
With this much screen space it makes perfect sense for ASUS to have gone for a 1440P resolution. 1080 would have ended up with noticeable pixels and 4K would require too much GPU hardware to maximise the performance. But 2560x1440 @ 144Hz is something that you can do with a good high end GPU, and two can really make the most of. Whereas you'd need at least two just to get a slightly playable frame rates at 4K. However, 1440 also ensures small enough pixels that the PPI is good and, even sat this close, you don't notice them. Additionally the panel is more than capable of driving the image smoothly. You would fear that such a gigantic screen might cause ghosting issues, but because it can handle 144Hz there is absolutely no ghosting either at the 60FPS limit that many games suffer from, or all the way up to the glorious 144Hz maximum. If you've only ever lived with 60Hz monitors then we really can't emphasise enough how wonderful it is to have the buttery smooth triple digit frame rates of which the Strix XG32V is capable. We had slight concerns about viewing angles of a curved screen but we needn't have been concerned. If anything at this screen size the curve helps keep the wider portions of the display free from the greying of blacks that can occur when you're not sat directly in front of your screen. Combining that with the excellent colour reproduction and wonders of the updated Adaptive-Sync technology and you end up with rock solid image at every frame rate that fills your vision with glorious images.
The stand, sometimes the weak point of a monitor, has plenty to recommend it too. It's extremely flexible, capable of adjusting 100mm up and down, -5° to +20° on the tilt axis, and 50 degrees of rotational movement. ASUS include a ROG logo disc that can be inserted into the base of the stand to beam a red ROG icon onto your desk. Those of you with a little more creativity than we possess can also use the included clear one to put anything you like there. Clan logos. Gamertag. The world is your bivalve mollusc.
The only, minor, fly in the ointment is the cost, but then you wouldn't expect a 1440P, 144Hz 32 inch curved ROG Strix screen to be cheap, would you? This is gaming at a new level, a vision filling, gorgeously hued whole.
Discuss your thoughts on the ASUS ROG Strix XG32V Curved Gaming Monitor in our OC3D Forums.
«Prev 1 2 3 4 Next»
18-12-2017, 16:36:26
looz
Basically AOC AGON AG322QCX with better QC, 100e price premium and without the ghosting issues?
Getting a bit tired of 1080p here, hmm. Quote
18-12-2017, 22:32:00
MacLeod
I agree that 1440 is the right spot for this size of monitor. I'm not all that big into the 4K hysteria that everybody else is at least not in screen sizes below 27. I'm sure you can find some differences in image quality but you're gonna have to look to find them and you're gonna have to be side by side with a 1440 to do it. Not to mention the huge load they are fr GPU's. A 1080 can rip thru just about any game at max settings and still take advantage of 1440 and a 1080 Ti definitely can. 4K, not so much.
I also really like that VA panels are making their way into the gaming segment with fast response times and refresh rates. I much prefer the VA image quality to TN which is what was pretty much our only option for the last forever or so. Still not sure how I would like the curved screen though. I wish there was a place around here I could check one out and see cause they do look intriguing.Quote
22-01-2018, 20:20:03
tolagarf
TTL would you recommend this screen for a Nvidia user? I have the PG279Q but that screen is just getting too small for my old eyes, and I find my 32" Omen screen much more enjoyable for everyday work and watching movies. I just need a good gaming screen to replace the PG279Q considering the 32" Omen is 60 Hz onlyQuote
22-01-2018, 21:06:27
AlienALX
Have you tried 70hz on the Omen?
I bought its predecessor (the B&O) and even though it says that 70hz is only for AMD I got it working no worries. Coils whine a little but image is solid.
Try out Adaptive and Fast Sync on the Omen and see how you get on. Fast should give you much higher FPS than the screen is rated for any way.Quote
22-01-2018, 21:08:04
tolagarf
It supports 75 Hz but only with Freesync. If you try to enable the screen above 60 Hz with a Nvidia card, you will get lots of frame skipping (I did test the UFO test and it was terrible)Quote
