ASUS RTX 4090 ROG Strix Review
Test Setup
As the RTX 4090 cards completely dominate our graphs we’re only comparing the ASUS Strix to the other RTX 4090s we’ve reviewed. Otherwise the gaps between them would be all but impossible to spot.
AMD Ryzen 9 3950X
ASUS ROG Crosshair VIII Formula
Corsair Dominator Platinum RGB Series DDR4 3600MHz
Corsair HX1500i PSU
Corsair iCUE H150i RGB Pro XT AIO
Corsair MP600 2TB PCIe 4.0 SSD
Corsiar Obsidian 500D RGB SE
Windows 11
Clock Speeds
When it comes to clock speeds the ROG Strix is, as with all ASUS ROG cards, supplied with an easy overclocking software setup, should you wish to go down that route. We’ll look at some manual overclocking at the end. For now we’re sticking with stock and, as you can see from the graph below, the Strix is alongside the Gigabyte and Nvidia cards, with the MSI Suprim X a fair distance ahead.
