ASUS Strix RTX 3080 Ti LC Watercooled Review
Borderlands 3
Published: 2nd June 2021 | Source: ASUS | Price: Air Cooled £1599 Watercooled £1799 |
Borderlands 3
Borderlands 3 saw Gearbox Software return to developing their most famous IP following the somewhat dubious reception The Pre Sequel received. Borderlands has plenty of settings to tweak and, despite looking superficially similar to Borderlands 2, it’s significantly more demanding upon your hardware. At higher resolutions only the most performance rich need apply. Naturally we run with everything at the maximum possible settings.
If possible better to get a FE 3090 for £1400 and if the cooler bothers you fit a waterblock and it will still be cheaper than the non reference 3080 Ti cards.
Now would be a good time for NVidia to launch an Ampere Titan, yes hardly anyone would buy it but the asking price would put a cap on non reference 3090s and 3080 Ti cards.Quote
