Asus VG236H 3D Vision Monitor Review
A Close Look
Published: 21st July 2010 | Source: ASUS | Price: £399.99 |
A Close Look
First and foremost let's take a look at the VG236H itself. Given that most things are still incompatible with 3D technology and those that are still require an excellent display, this is by far the most important part of the package. Even if it's the one that requires the least explanation within todays review.
If you read my review of the Asus VW266H monitor a couple of weeks back will remember that the stand was quite a letdown on an otherwise good monitor. We have no such issues here as the stand provided with the VG236H is excellent. The base, which we'll see in a moment, has rotation built in. The stand has the, ahem, standard tilt control. But we also have height adjustment. This is unlocked by removing the pin you can see at the bottom of the stand on the photograph to the left. The height adjustment is very smooth indeed.
When it comes to inputs we have the major three you're likely to need. HDMI and DVI are almost a given in modern times, and we also have the image parts of the component input. As the VG236H doesn't have speakers there is no need for the left and right phono jacks.
Shiny! If there is one word that can describe the bezel and stand of the monitor it's shiny. All of it is covered in a piano black finish which is amazing to look at an a complete dust and fingerprint magnet. At the base of the stand we have a big 3D logo and around the outside quite a wordy little explanation of the monitor and its main selling point. It's strange to see because once you've spent your £400 on the monitor do you really need to be constantly reminded of what you've brought?
On the bottom right we have an identical button layout to that which we saw on the VW266H and so I wont reiterate it here. Suffice to say it's the stock Asus adjustments, On-Screen Display and Splendid modes available on all the Asus range.
If there is one huge flaw in the design, it's that the piano black effect has been continued onto the screen itself. It's amazingly shiny, like a black mirror. It's so bad I've had to manually darken the screen in this photo to save you the horrors of seeing your erstwhile reviewer in his shorts taking the photo. The screen itself is actually as reflective as the bezel.
On the rear we have a 100mm VESA mounting should you wish to use your own stand. Thankfully the quality of the supplied one is such that this is unlikely. It's great to finally see an ergonomic stand supplied with a monitor, although unfortunately as this is a £400 monitor it does back up my earlier comment that the main way you can tell the difference between a cheap and mid-range monitor is the quality of the stand. Although I do accept that the inclusion of the nVidia 3D Vision kit does increase the price beyond what we'd normally expect to pay for a TN panel.
Along with the monitor we have two substantial weighty tomes and two CDs. One provides the monitor drivers and the other is for the nVidia 3D part.
Before you blanch in horror at having such massive manuals for monitors, they cover just about every language on earth and between the two of them combined there are only 5 pages in English.
The normal 2D image only imitates 3D through depth perception in terms of the size of object in reference to the foreground. The 3D vision is different in the like real vision one eye effectively sees slightly more of one side of an object and the other eye vice versa, your brain then combines the images to give you the overall image perceiving 3D.
This is probably why it takes some getting used to as your brain will see the 3D of your room and then a second 3D image of different depth on the monitor, hence why it might get confused and lead to some people getting headaches or sometimes just poor aim.
Like patting your head while rubbing your stomach however, the brain can be taught to distinguish between simultaneous tasks affecting the same area of the brain.
Apache pilots effectively learn to look like a Chameleon looking at different images with each eye and still maintaining an overall picture without feeling sick or losing perception of depth.
I think with a little practice it would be easy to adjust to the change in picture and you'd soon be fragging people the same as always.
Of course there's the fact you can still just watch films (if you didn't want to game with them on) providing the 3D movie experience at home.
I myself have bought a 3D vision monitor in preparation for my pc I'm still building (seems like ages, tho I did start planning it in feb lol).
We'll see how I get on eventually.Quote
